Applying deck patches
Put a very slightly soapy solution on the deck first then you can slide the patch around and get it in the right position with no wrinkles etc, then leave to dry for a day before use.
Absolutely agree with John... it's a faultless system... I dip kitchen roll in the solution wipe around the deck opening and go from there.  You don't have to leave as long as 24 hours, if it's in the warm a couple of hours will do
The use of water with altered surface tension as standard practice when I worked in the sign industry and using the standard deck patch material one drop of fairy liquid in a spray bottle is about  right..
If you are using the modern vinyl that they use for wrapping hen keep Dr and use a heat gun.
Thanks Guys I was aware of using soapy water to fix vinyl but didn't consider it for deck patch material. 'll give it a try. Michael
