March 6, 20206 yr Trying to find 6.6volt 2cell life batteries with an xt60 female connector.anyone know where i can buy them please.
March 6, 20206 yr Contact Vapextech.co.uk as they generally will make up a pack for your connection.. https://www.vapextech.co.uk/batteries/radio-control/6v-6-6v/ Cheers, JohnB
March 6, 20206 yr You could try the Component Shop who are very helpful and will fit XT connectors fir you
March 7, 20206 yr Hobby king do some, when they have stock. https://hobbyking.com/en_us/zippy-compact-1800mah-2s1p-30c-lifepo4-pack.html?queryID=81930c21e4be5dd5816b414adaf4b466&objectID=82544&indexName=hbk_live_magento_en_us_products https://hobbyking.com/en_us/zippy-compact-2100mah-2s1p-30c-lifepo4-pack.html?queryID=8b51fbc3434c162e175f2e9587fab9f6&objectID=82547&indexName=hbk_live_magento_en_us_products
March 7, 20206 yr 1 hour ago, Mike Ewart said: My local model shop suggested I buy direct from vape tex Can't see any 6.6v LiFe's on their site.
March 7, 20206 yr 5 hours ago, tiggy_cat said: Can't see any 6.6v LiFe's on their site. I posted a link above, repeated here , second row of batteries: https://www.vapextech.co.uk/batteries/radio-control/6v-6-6v/
March 8, 20206 yr Hi I use 1000 mAh 2 cell LiFe batteries from Component Shop. I solder my own xt30 on but he will put xt30 connectors on for you. https://www.componentshop.co.uk/6-6v-1000mah-lifepo4-receiver-battery.html
March 8, 20206 yr From the original post, it sounds like his winch has xt60 plug fitted which is a bit of overkill for the power concerned. You can buy xt60 to xt30 converter plugs on Ebay quite easily though.
March 9, 20206 yr On 06/03/2020 at 16:46, hawktastic said: Trying to find 6.6volt 2cell life batteries with an xt60 female connector.anyone know where i can buy them please. call either overlander https://www.overlander.co.uk/ or componentshop https://www.componentshop.co.uk/ they will fit the connector for you.
March 21, 20206 yr I use this version, direct from vapextech or you can get them from Mike Weston, both can also supply a suitable charger https://www.vapextech.co.uk/batteries/radio-control/receiver-packs/66v-1600mah-life-rechargeable-battery-vapextech-sq/ Its not a hard task to solder your own XT60 connectors but of course you do need a soldering iron Edited March 21, 20206 yr by Smiffy
October 22, 20206 yr Hi All I put my own connectors on , then sleeved the battery to hold the wires in place. Dave
