Shroud bottleneck deck eye hooks
I have the normal Sailetc type shroud hooks (wire bend to an angle) and I have seen a more compact attachment on some modern boats (mint/proteus etc) who supplies these?
Edited by Craig Olley
Found another example
You make them from the Sailsetc item. The bottle parts stays attached to the hull and you screw in the top part when changing rigs.
A couple of years ago Mr Potter was making a set of turnbuckles from stainless steel the set comprised 3 screwed sections to fit on the rigs and one section to fit on the hull, seemed a good idea worth che king it out
  • 3 weeks later...
