David Norris
Forum Member
Everything posted by David Norris
  1. And a very good thought it is too!
  2. This has now been looked at again, and results re-entered. The outcome seems to be satisfactory, but it does put an emphasis on the RO completing all races (any retirement/malfunction will adversely affect the RO as the average is calculated before discards come into effect, rather than discarding the retirement before averaging out). As John pointed out. Thank you for your contributions. We are learning!
  3. It’s across 7 races in a weekly event, making up a 9 event series. I was really trialling the RO role and went into A Fleet to see what it said about average points. I think I went in via Redress. I’m not very tech savvy but seem to have landed on something that I would describe as unsatisfactory and unlikely to entice others into taking on the RO role
  4. We are a relatively small club and use A Fleet for our race results. However, as our numbers are growing, I decided to act as RO in the first of 7 races to see how the average points worked out (for future reference). A Fleet took all 6 of my results and averaged them to produce a score for me in race 1. It did not allow me a discard before averaging. Other competitors had 2 discards over the 7 races, I had none - which seemed a little unfair. Is there a way of setting things up so that RO averages are worked out to allow discard(s)? Any guidance appreciated David
  5. Mmm. That sounds like good news for 65s. We’re up to V3 in DF95s, do you happen to know if these are equally exempt from the issue?
  6. Sound advice. Many thanks
  7. David Norris posted a topic in DF Racing
    I’ve read that it is advisable to seal deck eyes on new hulls to prevent potential water ingress. Presumably this is best done by removing the deck eyes first? Is there any danger that this might weaken the grip on the threads when reinserting? Should the deck eyes be reinserted before the seal is dry? Any and all advice appreciated David
  8. That’s very helpful, John. There is no mast ram on a DF95, nor shrouds, but I understand the principles behind your comments, which coincide with advice I have received privately. David
  9. Many thanks!
  10. David Norris posted a topic in DF Racing
    I’ve read that, in light airs, it is recommended that the main boom should be sheeted in a little more inboard. What is the logic behind that and should there be a commensurate adjustment inboard on the jib boom? The whole idea seems contrary to the “if in doubt let it out” principle. David
  11. Many thanks for all your advice. The only solution was a new sail servo, in the end. I was concerned to sail her again on Friday. B rig conditions, cold northerly. Would I get water in again? Happily not. I took extra care when sealing the hatch and remained dry for the whole evening.
  12. Ok, thanks I will try a spare receiver that I have first. They’re cheaper!
  13. It’s just a standard DF95 digital servo winch. The problem only arose once I discovered some water ingress. Could that have caused the servo to misbehave? Permanently? Thank you, John, for your input but it was a bit too technical for an amateur like me. David
  14. Sorry if this has been covered before/elsewhere, but what does it mean if my drum rocks back and forth a few mm without me touching the control stick? What might have caused this? Many thanks David
  15. Sorry if this has been covered before, but what does it mean if my drum rocks back and forth a few mm without me touching the control stick? What might have caused this? Many thanks David
  16. Can anyone identify this design of IOM please? The sails are signed, dated 1993
  17. David Norris replied to David Norris's topic in DF Racing
    Sounds good. There does not seem to be any need for a specialist paint, so it’s an easy fix. We now launch and recover from a floating pontoon so, once the bulb is restored, it will never touch bottom again. ‘Bye wellies!!
  18. David Norris replied to David Norris's topic in DF Racing
    For clarity, I’m really asking what sort of paint would you use and would a metal primer be required (once you’ve waded out to it)?
  19. David Norris posted a topic in DF Racing
    Hi I’ve seen this somewhere, but can I find it? Sailing my DF95 in a gravel pit the ballast comes in for a bit of hammer when coming ashore. Does anyone have any tips for getting it back into pristine condition - within class rules? David
  20. Thanks John. There had to be some reason for it to be changed. New bearings, presumably, will complete a relatively cheap upgrade. I am reassured
  21. Thank you
  22. Does anyone know whether the older version DF95s, with the original kicker arrangement, can still be competitive? Are they worth buying for someone just entering the class?
  23. I’m on it!
  24. Thank you both for your replies. Would the counterweight need to be wound out or wound in to facilitate a goosewing? Running by the lee can be very quick in my experience. That is true in both dinghy and DF alike. Asymmetrics are a different kettle of fish, of course
  25. David Norris posted a topic in DF Racing
    Any tips please as to how to improve my DF95s ability to goosewing? ……..other than me pointing the boat in the right direction of course! David
