Everything posted by David Norris
Sail winch servo
Thank you, John D
Sail winch servo
Thanks both. Yes, DF95. I did increase the tension on the elastic after having the line jump off the drum twice during racing on the same day. Sounds as if I have overdone it. I originally used the thin black elastic supplied by RC Yachts, but put a stronger piece on recently. I will ease it off. I’ve not heard of fishing pole elastic but my neighbour is a fisherman, so I will tackle (no pun intended) him. David
Sail winch servo
I’m sorry, I know this has been covered elsewhere but I can’t find it right now. I can turn the drum and servo with my finger and thumb with minimum pressure. If I try to hold my boat by the keel and flop it from side to side, to assess the twist, the sail goes out. When I switch off the boat, the winch winds under the tension of the elastic (too tight?). It’s a V2 servo with only light usage and seems to be performing well under sail. Any thoughts? David
Removing Sail Numbers
That’s a matter of personal preference, Derek.
Surgical spirit. Piece of cake. David
Short keel
Thank you, John. That’s a reassuring assessment. I’m going for it! David
Short keel
I’m trying to put together a club boat on the cheap. I already have a spare hull and a short keel. Q1: Does the ballast for the long keel also fit the short keel? Q2: How would performance of boat with short keel be affected (club sailing with A rig only)? Q3: Would short keel boat’s performance be less affected in light to medium airs? David
Transmitters receivers
I get that the Joysway transmitter originally provided as part of the RC Yachts package for DF95 has been largely superseded by the FlySky fs-i6, but I’m still struggling to deal with the Joysway on a club boat. Can anyone talk me through, step by step, the process for limiting the throw on the Joysway? I have the flat headed tool, and think I can identify the right “aperture” but please assume zero knowledge this end. Thanks in advance David
- Finger patches
Finger patches
Hi Do the finger patches on DF95 sails serve a purpose other than for boat identification or for aesthetics? Conversely, do they have an adverse effect on the way the sail cambers? Does anyone sail without finger patches on theirs? Regards David
Kicker df95
Hi Unfortunately, I am unable to attend the AGM on 25th. I’m sure it will be an informative talk, and I hope it will be videoed and put out to members David
Kicker df95
I’m slowly getting to grips with sheeting angles, backstay tension, leach twist etc but am still struggling to balance all this with the kicker. Does anyone have any “golden rules” ? David
Spreaders
Ha, ha. Point taken!
Spreaders
Wow, Martin! From all I’ve read, it seems possible that my B rig was never designed to have spreaders. Given that, I plan to set the boat up with the mast in the upright position, with equal tension on both shrouds. …..and a bit of rake. As a point of interest, have IOMs, from the get-go, always had spreaders?
- Spreaders
Spreaders
All good, Andy. I will give it a whirl. David
Spreaders
Yes, I see the logic of that. It’s just strange that the mast should be pre-drilled for hooking the shrouds on, but that there are no holes for spreaders to push through as on the A rig mast. I guess there is always the possibility that this is not the original mast. I plan to sail her this Friday (although there probably won’t be a strong enough wind to assess the job fully). David
- Spreaders
Spreaders
Thank you, Brad, for stepping in. My IOM is a Cygnet 2, very broad in the beam. Probably dates to c. 1990. It’s my first ever IOM and I am only new to rc yachts. The A rig has spreaders, the B rig doesn’t. The shrouds are at the widest extremities of the deck. I just wondered if this was how it was designed. The mast is round (no groove) goes through a tube to hull floor No mast ram. I accept that the boat will never be competitive, but I would like it to be the best it can be, without spending a shed load of money on it. I know that the A rig fits that bill, but I guess I will just have to suck it and see with the spreaderless rig. Regards David
Spreaders
I have an old IOM, with a B rig which seems to have no spreaders on the mast/stays. Is that unusual for IOM B rigs? Would performance be hugely affected if I sailed her just under stays? Regards David
Glued
Hi Peter Understood. That all makes very good sense and I’m very grateful for the guidance David
Glued
Not too late! The mast is unglued from the stub. I will look at what best to do with it now. I must make sure that whatever I do does not contravene class rules. I like the look of the site you directed me to and I have saved it. Many thanks David
Glued
Hi Nigel That did occur to me and have had a look at RC Yachts to see the costs of a mast plus stub. They’re not cheap! I’m relatively new to rc/model yachts, and am enjoying tinkering so, regardless, it’s a learning exercise. Thanks for your contributions David
Glued
Ok. I will be “going in” later today - once I’ve plucked up the courage….! David
Glued
Thanks. I will give it a try! David
