Widget IOM MAST RAKE
Anybody got any mast rake measurements for WIDGET IOM
Brilliant, I was needing this information too :-)
Edited by John Bennett
typo
Glad it help I’m assuming the rake is measure to where the bow bumper stick to boat
The diagram says it is measured to the stern of the boat.
Hi All,
Just to be clear, the rake measurement is taken from the mast datum point up from the deck, to the top of the Stem, not including the bumper. This is measurement is taken in full rigging trim under tension.
cheers
Brad
On 08/02/2023 at 22:48, Brad Gibson said:
Hi All,
cheers
Brad
Not having a background in boats I've just looked up "Stem" and found it is the other end to the "Stern", thank you for the clarification, I read it as "Stern" off the printout I made of your rake diagram, I'm sure I would have realised my mistake when I actually got round to measuring it :-)
Never really understood the point of raking the mast.  Back in the day there were a number of dinghy classes (like Enterprises) that had a fixed mast foot position, so the only way to balance the helm was to alter the mast rake, but for classes where you can move the foot, I would keep the mast vertical and move the entire rig fore and aft to achieve the desired balance.  Or am I missing something?
I would imagine it is to do with the fact it is much easier to have a system with a fixed mast foot than movable mast foot.
  • 1 year later...
Brad I see your set up guidelines says " deck edge used for lower datum point ". Iam taking a steel rule between the two sides of my Britpop and measuring up from there. Is this correct ? appreciate your help.
Hi Roger,
The Rake guide for the Widget attached in an earlier post above, takes the datum point from the floor of the cockpit.
I believe you might be referring to my Rake guide offered for my Alternative design on our website that suggests the datum be taken from the sheer line/deck edge due to home builders possibly using their own preffered decking style and datum points being inconsistent.
If you require a rigging and setup guide for the Britpop design, please drop me an email at bgrcyachting ‘at’ hotmail.com
Cheers
Brad
