Posted
When I plug the servo into AUX (Channel 6) on the RX it moves a little so I know it is active but I can't figure out how to control it from the TX! Nothing in the manual that I can see.
Trevor
AUX 1 or channel 6 is usually used for DUAL Aileron Wing Type or Flap and so must be enable in the programming menu.
Go into WING TYPE mixing and Enable or Activate DUALAILE and you will then have the AUX1 or channel 6 function properly.
OR
you can use Ch6/AUX1 for 2-position flaps operated by the Flap switch on the front of the Tx by setting up values in "Flap" under the Adjust list. If you don't set these up nothing happens when you use that switch.
Lots of stuff online, search for "DX61 aux"
Edited by John Bennett
Thanks for that.  I found a you tube vid with a step through.  I had been in the right place but hadn't changed the values by enough to make the servo move!
I am building an RC yacht rescue boat that needs three channels for the "jet drive", two for the electric ducted fan (backup propulsion and artificial wind) and the sixth for the hand that grabs the shroud!
Trevor
