September 23, 2025Sep 23 HiAny other owners in the UK, or abroad reading this ….. that could get in touch to share rigging measurements and tips,Would enjoy a chat, to make this fine Aus boat go fasterStephen Edited September 23, 2025Sep 23 by Stephen B
September 26, 2025Sep 26 Author Or many other fast boats around can also be ordered! Edited September 26, 2025Sep 26 by Stephen B
September 27, 2025Sep 27 Hi Stephen,You won’t go far wrong if you start with BG sails and design IOM rig setup guide and top tips.The MYA handbook for 2009 also has a good explanation of the basics as a great reference document.https://www.mya-uk.org.uk/kb/sail-trimming-before-going-afloat/Each design has its own nuances but the basics of rig building and set up are common across all IOM. Once you have a rig set up that is constant and repeatable you can make changes and find the best results.
September 27, 2025Sep 27 Author Great rig measurements doc arrived via email from red ant, and much better that version 1, clearer explanation.See if it goes any better…..
