iPhone based start countdown 1 minute
Does anyone know of an iPhone based start countdown 1 minute,  with idealy 30 second , 20 second and finally 10,9,8---- GO   Having the full 60 second count down is too much.
Or even anyphone based app
When I had an iphone, one challenge was that it wanted to use itunes to play sound files. I got around this by emailing the mp3 sound file to myself from my laptop, and then 'saving' the mp3 file on the iphone - it was a few years ago. so I am not sure of the details.
I use the AMYA start file and have a 1 minute edited version - will attach if I can.
replaces appleplay with itunes
1timer - voice timer
search for the app above.
quick timer is the function you need. You need to play either the setup to get a beep and the interval and speed and voice.
but once you get it right it is really perfekt!!!
Do I need the pro option to get a start klaxon or beep??
Thanks for you input on this.
I don’t have the pro.
my countdown has the the counting every 15seconds, the every five, the last ten every second and the I get a “Start” on 0
Here is what it looks like. I have a custom for the gun, and I set it to start.
it probably possible to do whatever you want.
this settings are for the quick timer. The gear when is top right above the num pad.
once you set it up it’s really perfect
