Hull numbers
Sorry if this has been covered already but I am relatively new here. All boats, when registered, are given a hull number on which to base their sail number.
Are people marking  this number onto their hulls, if so how?
David
Hi David
Yes you have to display the hull number on the outside of the hull, and most people use vinyl letters.
BUT as per the varying IRSA class rules (IOM, RM, A Class etc) the hull number must also be bonded, painted or etched to the inside of the hull. Vinyl letters on the outside are often removed during refurbishment and without the bonded in number the hull will soon looses it's identity.
If there is no number on the inside then it's fair to say the hull has not been registered.
