Posted September 19, 20223 yr Been sailing my Alternative for 5 years now and it has collected a few scrapes and knocks. I finished it in clear epoxy, mainly to strengthen the cedar planks and give a smooth finish. Not with any thoughts of "beautification" Going to do a refit and am considering a nice shiny coating now. I usually just go with the the aforementioned, technical approach and would appreciate any advice on options. A brushed varnish is going to be heavy, similarly a brushed coating epoxy; what about a spray lacquer ?? The existing surface would need prep; something like 100 wet & dry ? Recommendations / advice requested from those of you who produce "show standard" timber hulls; with the caveat of keeping weight down. For pics of the boat, go to my earlier Alternative build article on the forum. Thanks. Richard
September 20, 20223 yr I would rub down and fill any dings with whatever epoxy you used originally then use 2pack clear with UV protection to get the gloss back before cutting back with 1000 w&d for a fast satin finish. Or leave gloss and go a bit slower.
September 20, 20223 yr Author Thanks Steve, Like you say, I too prefer the 1000 finish for a more slippery hull, but just keen to try a full gloss for looks and possibly flat off after. What 2 pack clear have you used ? Loads on market and a lot of it comes in quantities to suit a super yacht. Also application preference. I know one brushed coat is about 30grms and 2 will be about 45 total after inter coat sanding. Richard
September 21, 20223 yr Richard I use U-Pol available in various size containers. I have never tried to brush, always use a touch up spray gun. My newly finished 6m has a gloss hull and a satin rudder. the reason is my wife chose the colour and caught me rubbing down the rudder and told me off as it was no longer shiney.🙄
September 22, 20223 yr Author Thanks again Steve, I use U Pol 2025 white Hi build for ballast and foil coating. Nearly as good as epoxy Hi build but so much cheaper. Flats down with 1200 Wet and dry to a super slippery Finish and easy to brush apply for those particular applications. Which U Pol clear coat ? looking at 2080 series and some appear to be single pack. Diamond 2080 sounds about right ? Will have to invest in a sprayer and learn how to use. I don't suppose the U Pol aerosols are worth considering ??? Richard
September 23, 20223 yr A friend uses two pack aerosol with good results no idea of make though. I have been using this https://u-pol.com/product/coatings/clearcoats/s2080-superior-hs-clearcoat/
October 17, 20223 yr Author Thanks for all the replies and info. I decided to stay with the epoxy coating. Main reason is that it adds strength to the cedar planking and gives a very hard finish that flats down beautifully. Yes that right ! changed my mind about the attractive shiny finish. Went against my principle of function over form. The 1200 finish is so much more slippery than a nice shine. Sanded hull with 120 then I used XCR epoxy, 3 coats wet on wet. Dry sanded 120 then 400/800/1200 wet. Hull is now the best it has ever been and also managed to sharpen up the chines. Have added more details on my "Alternative" build thread. Richard
