Trevor
Everything posted by Trevor
  1. I'm replacing my pot as it has gone brittle. The one that came out had a number of holes in the sides for the various leads but I'm thinking one in the bottom with grommet and sealant would be better. Slightly off centre to allow for the battery to rest on the bottom. There will be one small hole near the top as that's where the aerial tube is glassed in. Is this the right way to do it or do you have any better ideas. Cheers Trevor
  2. Trevor replied to Trevor's topic in IOM
    So far so good. Due to the difficulty of accessing the top of the tube under the deck I made a small collar to stop the tube pulling through the deck and added epoxy during assembly. Having drilled the bottom the bottom of the tube I put a long pin through that was then glassed to the keel area in the same way other fittings are fixed. Don't think that's coming out anytime soon! Thanks for your help. Cheers Trevor
  3. Trevor replied to Trevor's topic in IOM
    Richard Sailsetc headsail swivel tube product code TUBEJ under Hull Parts shows the parts and the description that you gave earlier and useful pictures. All ready to go now! Just need to take the plunge with the glue. Cheers Trevor
  4. Trevor replied to Trevor's topic in IOM
    Richard I see those last few boats have the same system. On closer inspection of my tube I find a ball with a hole located by three dimples a half inch from the bottom. The line was knotted below the ball. I'm wondering if I should install pin instead and loop the line back up to deck level to provide adjustability? Cheers Trevor
  5. Trevor replied to Trevor's topic in IOM
    Thanks Richard. I will have a go at that in the morning. It seems as though it has been done before as I have a bit of cleaning up to do first! I have looked through a lot of Sailsetc documents but can't find the bit about the line in the tube. Cheers Trevor
  6. Trevor posted a topic in IOM
    I'm a complete beginner to this hobby and on my recently acquired ISIS the tube that takes the headsail boom pivot has pulled out of the hull! Before I glue it back in are there any recommendations as to the best way to set this up? Also any links to web pages regarding the fittings and adjustments of an ISIS would be gratefully received as although my fellow club members are exceedingly knowledgeable and helpful I don't want to be a pain. Cheers Trevor
