  2. Is there anyone on this forum who atended bothe the M/1OR Worlds last year and the IOM Worlds this year? If so I would be very interested to read their opinion on the windward gates used: M/10R: inside out gate with offset marks on both sides of the gate IOM: outside in gate In particular I wish to know if, in your opinion, different gates: reduce the number of incidents at the windward mark; distribute or concentrate the fleet at the start of the run; allow boats to bail out if they mis-mis-judge the lay line, or which to avoid a congested mark facilitate the work of the observers and umpires; facilitate the setting of fair courses. As a judge/umpire a both events I have a personal opinion which I wil reveal if this thread has some replies. I may well be that my opinion will be very different ffrom that of competing sailors.
  3. Last week
  4. Paul Deane joined the community
  5. michaelmorris joined the community
  6. I've run an extension/ charge lead up to the small patch hole and just cover this with some clear duck tape. The main patch never comes off. The lead is wedged up with some foam in the hull so the end of it doesn't get lost in the hull.
  7. I recommend against charging Lipo or Life batteries in the boat- risk of explosion or fire. I always use a charging safety bag. John
  8. Where are you based please Luke?
  9. Mike Critchlow started following DF95 & Sails
  10. Surprised that I have yet to find a solution for charging the battery on a DF65 without removing the adhesive patch. Has anyone found or is using a suitable 2 pin connector that could be let into the plastic stern cover with a waterproof outer cover?
  11. Elliot Hanson joined the community
  12. Jonathan Gillmore joined the community
  13. Clive Odell joined the community
  14. David Viner joined the community
  15. JohnT joined the community
  16. The IRSA Race Management Policies state: General Recall 8.1In case of any problems with the starting line (such as length, or angle to the wind,etc.) a postponement may be signalled, even up to the last second before the start, instead of a general recall. 8.2 If a race management error is discovered after the starting signal (e.g. timing), the course management team may abandon the race. In these circumstances, the course management team will not signal a general recall. 8.3 When the course management team is not satisfied that all boats over early (or that have broken rules 30.1, 30.3 or 30.4) have been identified, a general recall will be signalled. 8.4 In the event the start has been postponed, or a general recall has been caused by the length or angle of the starting line, the course management team will adjust the starting line and make another attempt using the same preparatory signal. 8.5 If the course management team is satisfied that a general recall was not the result of the length or angle of the starting line or a course management team action, it will signal the use of a rule 30 starting penalty (I flag, U flag or black flag) for each subsequent attempt to start the heat 8.6 An important principle to be followed by the course management team is that rule 30 starting penalties will only be used when general recalls are caused by the boats themselves, or rapid oscillations of the wind, and not by actions of the course management team. 8.7 When using the black flag, the course management team will make every effort to signal a postponement in the event of any problems with the starting line. These policies closely mirror those of WS.
  17. This is the fundamental flaw of the outside in windward gate. At the M/10R Worlds last year the RC set an inside out gate with offset marks on each side of the gate. Once the sailors had worked out how this worked there was a significant reduction on incidents at the mark. Few boats attempted an approach on the port layline. Instead boats approached on the starboard layline of both marks. Boats that came up the left hand side of the course would sail to the left hand mark layline. Boats on starboard would form two queues along the layline. One advantage is that if there was an issue ahead it was always possible to bail out at the last moment by heading for the other mark (either by tacking or bearing away). This is an advantage when the marks have to be set some distance from the shore. As boats arriving to the right-hand mark had to tack to round the mark, the RC set the offset leg on that side slightly shorter
  18. I may have copied 7 rigs worth of settings onto my spare by then !
  19. Thanks John - left stick issue….
  20. Thanks for the suggestions- my thought was the pot on the transmitter so will try another channel.
  21. As suggested, first try the winch in another channel. If it still does it, then dirt / corrosion / damage in the winch feedback pot is most likely. If you can dismantle the winch and spray contact cleaner onto the track, then this might cure it. The problem is that having gone bad once, it is likely to do it again. If it's an RMG then replacing the pot is fairly easy (though expensive for the older 10 turn types). For other types, manufacturer's spares are hard to come by and finding a generic part that fits properly is also tricky. Depends how seriously you sail, but a new winch and keep this one as a spare might be the best option for a non-RMG.
  22. hi Jeff, You'll need it fixed for the big event in July!!
  23. When you say a glitch do you mean like the winch shudders or is searching. Does it do it in all positions. I had a chuddar at close hauled. I remedied it by removing drum and turning it a 1/4 turn and it went away. You might also try resetting your EPA on tx
  24. Try moving the winch plug on the Rx from CH 3 to CH2. Then move the right stick up and down. Has the glitching gone away. If yes, then it could be the pot on left stick of the Tx. If not, then it could be corrosion on the plug on the winch or the winch. John
  25. I think that the biggest con at the moment is that they have been out of production for quite a few months now. According to the web site, this is due to machinery breakdown. Other than that, I find them pretty reliable, having several IOM and A class size versions.
  26. Has anyone experienced glitching on the sheeting stick on a Futaba 6j ? If so any potential solutions? Thanks
  27. Colin Helliwell replied to Tom's topic in IOM
  28. Colin Helliwell replied to Tom's topic in IOM
  29. Eric Finley replied to Tom's topic in IOM
  30. Both the KingMax and PJ sails winches are fully enclosed cases! I think they both claim some level of water ingress protection. The KingMax are standard servo size cases, I believe the PJ sails cases are slightly larger. At least with the RMG you can monitor the condition of the gear train and maintain as required. A motor failure is also not life threatening to the winch. If your boat is reasonably water tight you should not have problems. Why not give Bill Green a call and I'm sure he will talk you through the RMG's pros/cons.
  31. Hard chine design 36. I sailed it once and have not used it since - cannot get the grandchildren to Gosport! I suit of sails, simple vane gear. £50 ono better used than in my loft.... 07818413515
  32. Paul Tickner posted a topic in IOM
  33. Thank you for your suggestions. I’m currently emailing K7 to see how much we’re talking. My quibble with RMG is the open nature of the winch - I like things in boxes or pots - but I know they work perfectly well!
  34. Colin Helliwell replied to Tom's topic in IOM
  35. Gary Currier joined the community
  36. Peter Ditcham joined the community
  37. Colin Helliwell started following Sedici
  38. Tom posted a topic in IOM
