  1. Yesterday
  2. Britpop IOM. Hull No 3567, built by Robot Yachts, light blue hull with silver fin and rudder and a light blue bulb RedAnt Winch JX Digital Rudder Servo Futaba T6K Transmitter and receiver Stand and carry frame Wooden sail box TX cover A rig with Brad Gibson sails (shown on the boat) A, B and C rig with Graham Bantock Sailsetc sails (shown in the sail box) Unused Brad Gibson B sails, Main and Jib with boom (photo) Unused Brad Gibson C sails, Main and Jib with boom (photo) Used BG A Jib Used SailsEtc A Sails, Main and Jib Spare Fin and Bulb 2x Overlander 2000mah TX battery packs and charger. Battery Tester 3x 5 cell Overlander Tornado 1600mah Boat batteries and charger Unused Futaba S3014 Rudder Servo still in original box Spare shrouds and C rig gooseneck. Certificate is missing but the boat is registered and measured on 24th Jan 2013. The new owner will receive the certificate from the registrar on request. The boat is in Portsmouth, Hampshire. £1950 Phone Richard 07811 000 752
  3. Boat number 1381 little used in recent years. Model - Sweet 3, Hull and appendages by PJ Sails 2 Suits of No 1 and No 2 Sails, 1 No 3 Main Transmitter and receiver £525 Contact Lawrie Draper on 01794 390181 Radio A Class Yacht for Sale.docx
  4. Yes - I removed the sail and measured the current bend 15mm to centre line of the mast, does look to be all in the last 150mm top of the mast. Luckly I also have another A-Rig on my other boat, same sail maker and the sail maker is also from our club so will check with him. Many thanks for replying
  5. Last week
  6. Trevor replied to Craig Olley's topic in IOM
  7. Trevor started following A-Rig mast prebend
  8. Ditton Dabler replied to Stephen B's topic in IOM
  9. CaptainScarlet replied to Stephen B's topic in IOM
  10. Stephen B posted a topic in IOM
  11. Stephen B started following Best glue….
  12. Andrew Langford joined the community
  13. Norman Rowley joined the community
  14. Hi John949, Yes See R 14. Avoid Contact - and then if you think a rule has been broken, protest. John
  15. Craig Olley posted a topic in IOM
  16. ALTERNATIVE IOM 4735, with Certificate, competitive boat wining several club race series. Moulded hull painted with the excellent Epifanes two part paint. David Creed fin, ballast and rudder. A rig with Sailboat RC sails, B and C rigs with PJ sails, PJ sail winch. PSN will be removed. Spare deck patches and templates. Radio, receiver and stand NOT included. Based in Dorset, but will discuss possible delivery arrangements. £1300
  17. Note that the term 'full & by' was dropped from the RRS many many years ago - replaced by 'close hauled course' Oops, showing my age. Still I do know that the "overtaking boat keeps clear" rule was dropped equally long ago (unlike a lot of people it seems). It is one of the (many) difficulties of Radio Sailing that judging "proper course" when sailing perpendicular to the observer is not easy. My understanding is that if you get overlapped to leeward you are required to keep clear and protest afterwards (if you believe the leeward boat is sailing above her proper course) - not ignore the leeward boat and watch the boats raft up.
  18. Thanks Derek. I did find this on YouTude, which is a help https://youtu.be/tGsTGVfTSSA?si=xdiur-Y0T60bBdB-
  19. I already told Norman it's a KLUG, made in Germany in the 1970's They also made a Marblehead (Gibli) and a 10r but I can't remember the name. Nice to see that you' ve got it together.
  20. Hi RoRo, I suggest you look in the WS Case Book and share with your fellow sailors. Look at cases 15 and especially Case 27 for applying R 13. Case 27 is exactly the described issue. Rule 13, While Tacking CASE 15 In tacking to round a mark, a boat clear ahead must comply with rule 13; a boat clear astern is entitled to hold her course and thereby prevent the other from tacking. CASE 27 A boat is not required to anticipate that another boat will break a rule. When a boat acquires right of way as a result of her own actions, the other boat is entitled to room to keep clear. Also for R 15 see Case 81 however that is a marks to stbd scenario. CASE 81 When a boat entitled to mark-room under rule 18.2(a)(2) passes head to wind, rule 18.2(a)(2) ceases to apply and she must comply with the applicable rule of Section A. John
  21. This happened to me at the weekend and the boat involved refused to do a turn and just said l was on starboard. At club level the argument is not worth the trouble but how do we sort this at an event especially with a he said she said?
  22. Hi Colin et al, I cover the subject of boats tacking at the stbd lay line on my web site - scroll to the bottom and look for my Appendix C When is 'tacking too close' too close? John
  23. Obligation to give time and room to keep clear does seem to get 'forgotten', esp. at windward marks. And, with the tacking aspect, can get 'subjective'. Often worthwhile, I think, even if you are going to complete your tack in adequate time, to let the other boat know. Unless in a title-deciding match race, then a collision is likely to disadvantage both (or more)....
  24. Hi John949 what you are describing is a clear breach of R 13. In addition, as ROW has changed, R 15 also applies briefly and the port tack boat must be given room to keep clear once STBD reaches close hauled course. Note that the term 'full & by' was dropped from the RRS many many years ago - replaced by 'close hauled course' John
  25. Norman McColl joined the community
  26. Mark Prue joined the community
  27. Chris Elsworth joined the community
  28. Michael Pickles joined the community
  29. Or they will generously warn you that they are "Tacking", as if that absolves them of the fact that they are tacking in your water or into you!
  30. It has Robbe parts in it, but it isn't a TopCat. It could be a Cat 460, but I rather doubt it. The mast adds about 2m of height. If anyone does know what it is, I know we have mixed up the port and starboard hulls. Picture was taken during very first test assembly while we tried to work out what we've got. Any information gratefully received. Thanks Mark
  31. Mark Blinkhorn joined the community
  32. In a similar vein, a yacht tacking from port to starboard does not gain starboard tack rights until her sails are full on the new tack. In my opinion, if the port tack vessel has to start an evasive manoeuvre before the starboard tack yacht's sails are full, then the tacking yacht has broken Ruel 13. Unfortunately I seem to be in a minority on this point as yachts to leeward and slightly ahead on port think they can tack with impunity and yell starboard as they come head to wind,
  33. Has Yellow finished correctly? She hits the finish mark as she finishes, so she needs to take a penalty turn and cross from the course side. She gybes to port and rounds up, passes HTW and then crosses the line before reaching a close hauled course. So has Yellow completed her penalty turn? I have written a new short article on what constitutes a tack. It is on my web site near the bottom of the home page - see Appendix D What constitutes a Tack https://sites.google.com/site/johnsrcsailingrulesandtactics/ John
  34. Thank you Gordon, I’ve had a bit of input from Craig so now I have a much better idea now of what he was doing. Is your hull rubbed down then polished or painted?
  35. I'm not going to the worlds but my daughter and family live in St Albans. So, either I could meet you there at a date to suit, or at a pinch I could bring her to Datchet and then spend the night at St Albans.. Would this help? Gordon
  36. Don’t suppose you know anyone coming south for the Worlds that could transport to Datchet?
