Windward gates
Same answer as Derek, approach mark doesn't help, it just moves the problem.
Windward gates
Gents, Nowhere in this discussion have you mentioned the common problem where, with WW & spreader, the incidents where 1 lucky boat gets away and the rest is just a pile up caused by port boats not giving way to stbd. I agree that a mark say 6 lengths to leeward will reduce the problem at the WW mark, but it still creates the same problem at the new mark. (Believe me I've tried it several times) Until the umpires start giving some Rule 2 DSC's to the port boat chancers, (if they can identify them) the problem will never go away.
Hi Nigel, welcome back to Fleetwood. the NOR is being prepared and will be posted soon. Then you can enter and have your spots!! Looking forward to seeing you. D
Steven Marriott joined the community
Mervyn Watson joined the community
Annabel Taylor joined the community
Windward gates
Windward gates
Windward gates
Colin B started following BritPoP IOM For Sale
Windward gates
Windward gates
Colin B joined the community
Black flag rule
