Unidentified model
Unidentified model
Unidentified model
DF65 Bare Hull & A Sails
Colin Helliwell started following IOM Worlds daily report?
- Earlier
I watched all of the seeding races and then only the A fleet races for races 2 and 3 as life is too short! The impression I got was that they would upload races on later days as soon as they could but it must have been a good 3 1/2 hours if you'd watched all of yesterday ! I also noted that they said that the couldn't afford the live streaming that the Australians had managed due to the exorbitant cost in the UK which is a sad reflection on how we pay through the nose for everything! I don't blame the MYA for being sensible.
