  1. Yesterday
  2. Barry T joined the community
  3. Scott Neale joined the community
  4. Ronald Clark joined the community
  5. Iain Thomson joined the community
  6. Stuart Yates joined the community
  7. Chris Maher joined the community
  8. Jack Stockford joined the community
  9. The inside out gate used at the M/10R Worlds with additional spreader marks turned downwind legs at that race into pure lottery. The beauty of what we do is that clever tactical racing is and should be rewarded. Do we want to further dumb down the sport by having a close race between 2 competitors choose gate and spreader options (under a weather bank) to round near 25+ metres apart and see who is lucky enough to get the unseen gust through trees? Without the other having any chance to attack or equally defend, this is not racing. All of this because we either don’t know how to overlay a windward mark in waves and wind for a clean rounding or don’t respect our opposition enough to take a transom? We can all get it wrong, but persistent offenders are not that hard to weed out at bigger events if willing. Weeding the club or local offender (bully) maybe not so easy…. Yes we want a clean race, but it should still be a race that rewards race craft, not further increase of luck. Regarding Umpire use of R2 and having to have a level of certainty, why did they not use a video option if in doubt as they were happy to ‘selectively’ use for an early incident? As for distances, of course nobody wants an eyesight test. The reports from the last IOM Worlds in Australia paint a mirrored picture of any umpiring issues being blamed largely on distance. What was conveniently overlooked was the start/finish line being within clear view of a raised platform of skippers where the largest number of unpunished rule breaches occured worthy of R2 hearings. Are our issues course distance related, venue related, skipper behaviour related or umpire standard related? It might be worth a bigger look at how all areas can be improved not just throwing people under buses….
  10. Brad Gibson started following Windward gates
  11. Brendan Finnegan joined the community
  12. I was at both events and personally favour an in/out gate with a set of spreader clearing marks. If we are honest, all options can create issues due to the control area and its proximity to the marks of the course with the prevailing wind direction. This is one of the limitations of our discipline. The higher the level of competition the more that the windward marks become an issue, the boats and skippers tend to be matched more equally and the competitive spirit higher, leading to more skippers arriving at the same time and more carnage and frustrations. We all know the issues and all fall foul of a misjudged lay line and the resultant pile ups, although never our fault!! If correct then the windward gate should reduce this by offering two options splitting the fleet, however as we know the gate tends to be used when the course setting is not easy so getting a fair split becomes difficult. To minimise the unequal gate they are usually placed closer together which then pushes more of the problem to leaving the mark. IMO the clearing mark option with an In/Out gives a further option to split the fleet equally as these can be offset to allow the gate itself to be within a visible range, and using the clearing mark to create a more equal next leg of the course. Pierre and team did this very well in France IMO and is the option I try to use when setting a course in difficult conditions, although it does then require more vigilance by skippers and race team to police.
  13. Built by Robot Yachts in 2018. Hull No 10. in Dark Blue . Spare rudder. RMG winch and JR rudder servo. A swing rig with gizmo. B, C, C2 , C3 pocket luff sails by Brad Gibson. Sail box. All in excellent condition! Boat stand , boat and keel bags. £4250 Email jjsmith61@icloud.com
  14. JohnSmith started following Grunge GBR 5183
  15. When using the inside out gate with offsets on each side we observed that most boats made a starboard tack approach. The result: two lines of boats each on the layline to the mark. The boats on the leeward layline could bail-out by tacking, those on the windward layline by bearing away. They would then round the opposite mark, passing a short distance to windward of the mark, avoiding any congestion.
  16. It would mean a lot of boats coming on starboard layline across between marks, worse for downwind boats...
  17. https://www.airbnb.co.uk/s/homes?dynamic_product_ids%5B%5D=1173826328498577944&omni_page_id=36021 New airbnb house on Fleetwood promenade half mile from lake. 47 the Esplenade. 5 bedrooms 3 bathrooms spectacular sea views from Gin & Tonic balcony Recently tested & approved by Gosport MYC classic & vintage marblehead sailors!!
  18. Last week
  19. If we must have a windward gate (not a big fan) then maybe we should just have both windward marks as port rounding, for the obvious reasons.
  20. CaptainScarlet posted a topic in IOM
  21. CaptainScarlet started following IOM VISION
  22. Good afternoon, Is the boat still available and if so, where in Dorset are you? Also, is your price negotiable? Many thanks. R.
  23. Thank you Derek for pointing us in the direction of one key point in the discussion. He refers to the issue of identifying boats. Many of the issues encountered at the windward mark disappear or are significantly reduced if all sailors and race officials can see what is happening! If all participants can easily read sail numbers this means that they can also better judge: Laylines The distance between overlapped boats Whether boats are on a collision course When the marks are set too far away, umpires and observers spend a great deal of time just trying to read sail numbers, in case there is an incident. This is especially the case for the umpire watching the far end of the start line. At Datchet there was hardly a start at which umpire and observer could read the sail numbers of boats beyond the outside start mark. There are particular issues at the windward mark when it is set more than about 65-70m from the control area and the fleet is sailing from right to left. Boats on port are sailing away from the shore and the sail number is invisible. The boats approaching on starboard cannot judge accurately if they are on the lay line, above it or below it. So we have, for the observer or umpire, two orn more unidentified boats heading towards the area around the mark (NB, in certain lights at Datchet even hull colours were difficult to see). The worst pile ups at the windward mark in these conditions are frequently caused by the starboard tacker, realising, when they have already entered the zone, that they are below the layline. If they are only slightly below, they may attempt to luff, causing boats outside and astern to also luff and slow, even stall. Otherwise the boat (still unidentifiable from the control area) will tack and aim for a gap that may or may not exist. If the gap does not exist, chaos is almost guaranteed. Even if the observers and umpires can follow the (unidentified) boat until the sail number is legible (often just before or after the offset mark) the damage has been done. The race has been ruined for several boats. There is also an issue with umpiring culture. Umpires will not penalised a boat unless they are certain that the boat has broken a rule.They will need to be even more certain before giving a penalty under RRS 2, Fair Sailing. The obvious solution is to lay marks closer to the control area. This creates other issues, as race officers wish to set a balanced windward leg. When the course is close to the shore, both sailors and race officials can see what is happening. The number of incidents is greatly reduced, and the percentage of incidents resulting in an umpire decision increases. So, when choosing a venue for a major event, a key criteria should be 'can the race committee set courses in all (or at least the most frequent) wind directions with marks less than 65-70m from the shore?' I have come to believe that there are very few venues that can met that criteria. I have been to a few venues that did meet that criteria - Fleetwood (the lake is only 62m wide), Limone (on Lake Garda), Nynasham I hope I spelt that right,) (Sweden , DF65 Globals), Ste Hilaire (only on the far shore, but the distances to walk were enormous) to mention a few. One issue in Datchet, as an umpire I was making a concious effort to walk up as far as possible to get close to the windward mark, to get as near as possile to the leeward gate and to get to the finish line. At most events I would be close to at least the better sailors in the heat. This was far less the case during the Worlds. In particular, many sailors were standing well to leeward of the finish line. I remember one leeward gatemark rounding where there were only 1 or 2 sailors with 50m of me. I think I hailed 4 mark contacts and note 2 marks not rounded. I am fairly sure that the competitors, from where they were standing, did not see the mark contact.
  24. I have a Futaba 7C Transmitter and R617FS Receiver for sale complete with manual and original box. Asking price £100. I also have additional Receivers for £25 each. Contact by email. tp.mbryc@yahoo.com Leicesteshire area
  25. FLEETWOOD MODEL YACHT CLUB A WEEK & THE CRABBERS Those who attended the Vane A Nationals at Fleetwood in 2024 will remember the problems caused by boats fouling crab lines and sailors struggling to attend to their boats on the bank due to families populating the bankside. In order to try to remove this problem, we at the club have consulted with council officials and obtained permission to “rope off” the lake as much as possible and erect notices to the effect that from Sat 25th July to Sun 2nd August the Model Yachting lake is closed and “crabbing is in the boating lake” There will be at least 20 of these A3 sized notices placed around the lake and at the entrance to the carpark, and on the walkway to the bridge. We hope that competitors will understand that we, the club, with the support of the council are doing everything we can to solve this problem. Thankyou for your understanding. We look forward to welcoming you all to our “9 days of A’s” vane & radio A regatta. Derek Priestley Fleetwood MYC
  26. Same answer as Derek, approach mark doesn't help, it just moves the problem.
  27. Gents, Nowhere in this discussion have you mentioned the common problem where, with WW & spreader, the incidents where 1 lucky boat gets away and the rest is just a pile up caused by port boats not giving way to stbd. I agree that a mark say 6 lengths to leeward will reduce the problem at the WW mark, but it still creates the same problem at the new mark. (Believe me I've tried it several times) Until the umpires start giving some Rule 2 DSC's to the port boat chancers, (if they can identify them) the problem will never go away.
  28. Hi Nigel, welcome back to Fleetwood. the NOR is being prepared and will be posted soon. Then you can enter and have your spots!! Looking forward to seeing you. D
  29. Finley Dickinson joined the community
  30. Ben Grenger joined the community
  31. I suggest another option for consideration - use a wind mark and offset mark with the addition of a windward approach mark. The approach mark would be set about 6 boat lengths to leeward of the windward mark and have a required side that all boats must pass it to port. The idea is that boats coming in from the left side of the course on port, would be encouraged to get on the stbd lay line sooner, and if possible, outside the zone. John
  32. I have sailed last IOM Worlds and I have watched last day of M Worlds with inside out + spreader. Outside in gate is somehow dangerous when boats downwind cross boats upwind just after the mark, but it reduces the incidents at windward mark(s) compared with classic spreader. My opinion is to avoid this option if gate is far away and if there is a lot of wind and use usual spreader. If boats are far and fast, you risk hits, and strong ones. Inside out + spreader is maybe the best option to avoid incidents, but : 1/ it's a nightmare for mark layers to get something fair 2/ Boats are so much separated at the beginning of the run that if you are on the wrong side, you are dead... The same without spreaders is easyer for mark layers, but you still have to go around windward boat on the layline before going downwind. So course is somehow shorter for boats not leading. To use Gordon's questions : and comparing with classic spreader Outside in reduce the number of incidents at the windward mark => Yes distribute or concentrate the fleet at the start of the run => Similar allow boats to bail out if they mis-mis-judge the lay line, or which to avoid a congested mark => Yes facilitate the work of the observers and umpires; => You would know, probably easyer as boats are separated facilitate the setting of fair courses. => No Inside out + spreader reduce the number of incidents at the windward mark => Yes distribute or concentrate the fleet at the start of the run; => Distribute (too much) allow boats to bail out if they mis-mis-judge the lay line, or which to avoid a congested mark => Yes facilitate the work of the observers and umpires; => No, more marks to check facilitate the setting of fair courses. => No, worse of all
  33. I have a ferry I have accomodation Now I just need a spot (actually two) on the entry list. 😄
  34. At the M & 10R Worlds we raced with the "classic" windward mark / dog leg, a windward gate inside out and finally the gate plus spreader marks. I didn't sail the IOM Worlds but have sailed multiple regattas incl. the last German M nationals with the outside in gate. The outside in gate is my least preferred option. If you are at the front of the fleet this creats a choke point where you are forced through the middle of the course with boats approaching / crossing from both sides on their way to the respective side of the gate. The videos of the last major IOM events provide a host of examples where front runners loose numerous places due to incidents caused by bunching up all of the fleet. The inside out gate in France worked well (allthough some managed to forget about the spreader and were DSQed multiple times) as it separates beating and running boats and was tactically challenging. However, depending on the lay of the land, the course and prevailing wind a windward mark with dog leg can work just fine.
  35. No PRO/umpire experience from me, not even that much RC sailing. My racing is typically a single spreader, though an outside-in was also used at our Open this weekend. One thing I sense though is that the efficacy of any method can still be upset by the angles. It's not always practical - esp. at events lesser than the Worlds kinda level - to be moving marks constantly, but a heavily shifting wind can result in laylines wandering such that any method can end up messier than the 'theory'. And of course the distances between multiple marks, and even distance/bearing from Control Area. A degree of 'horses for courses' perhaps, or [apologies for any earworms] 'it aint what you do, its the way that you do it'..?
  36. Is there anyone on this forum who atended bothe the M/1OR Worlds last year and the IOM Worlds this year? If so I would be very interested to read their opinion on the windward gates used: M/10R: inside out gate with offset marks on both sides of the gate IOM: outside in gate In particular I wish to know if, in your opinion, different gates: reduce the number of incidents at the windward mark; distribute or concentrate the fleet at the start of the run; allow boats to bail out if they mis-mis-judge the lay line, or which to avoid a congested mark facilitate the work of the observers and umpires; facilitate the setting of fair courses. As a judge/umpire a both events I have a personal opinion which I wil reveal if this thread has some replies. I may well be that my opinion will be very different ffrom that of competing sailors.
  37. I've run an extension/ charge lead up to the small patch hole and just cover this with some clear duck tape. The main patch never comes off. The lead is wedged up with some foam in the hull so the end of it doesn't get lost in the hull.
  38. I recommend against charging Lipo or Life batteries in the boat- risk of explosion or fire. I always use a charging safety bag. John
  39. Where are you based please Luke?
  40. Mike Critchlow started following DF95 & Sails
  41. Surprised that I have yet to find a solution for charging the battery on a DF65 without removing the adhesive patch. Has anyone found or is using a suitable 2 pin connector that could be let into the plastic stern cover with a waterproof outer cover?
