September 2Sep 2 Hi AllI have a P&P Yachts Vision IOM and my rudder shaft is bent to the side slightly and I have damaged the top edge of the rudder trying to match the profile of the hull, can any body recommend people who make rudders for IOM.I have checked Sailetc and their ones they sell don't match the one on my boat.
September 2Sep 2 John Gill of the right tension gauge has been known to turn out a good rudder, ask him
September 2Sep 2 Hi CraigTry:- David Creed, Mouldings, Fins, bulbs, and rudders 0151 342 7693. Does not have web site. (Found in past to be very quick to supply a rudder/fin. He supplied the early Uk Britpop rudders and fins)Robot yachts who also produce their own fins and rudders.Nylet also advertise IOM rudders and fins.Eric
September 2Sep 2 14 minutes ago, Eric Finley said:Hi CraigTry:-David Creed, Mouldings, Fins, bulbs, and rudders 0151 342 7693. Does not have web site. (Found in past to be very quick to supply a rudder/fin. He supplied the early Uk Britpop rudders and fins)Robot yachts who also produce their own fins and rudders.Nylet also advertise IOM rudders and fins.EricI'd also thought Dave Creed - might be able do it to custom to sketch/measurements Edited September 2Sep 2 by Colin Helliwell
September 2Sep 2 Unfortunately my main conduit to David Creed recently died. However I know David experimented with different profiles, his earlier creations were more like a Spitfire wing before he moved on to the trapezoidal later version, also know he experimented with longer but narrower designs. Hence the best thing to do is talk to him.
September 2Sep 2 Looked at Mark Dicks Web site and some photo's and the rudder shape on the IOM's I looked at seem to use a trapezoidal rudder design.Dave Creed was/is building the Viper which is a Mark Dicks design, I presume he uses his standard rudder design shaped to the hull.
September 12Sep 12 Hi Craig, have you managed to source a replacement rudder? If so from what supplier?
September 13Sep 13 Author Hi EricSorry from not getting back to you sooner, yes I was put on to David Creed but somebody from my club and should have my new rudder next week.Many thanks for replying.CheersCraig
