Edited by Jeff Kay
Typo
Try moving the winch plug on the Rx from CH 3 to CH2. Then move the right stick up and down. Has the glitching gone away. If yes, then it could be the pot on left stick of the Tx. If not, then it could be corrosion on the plug on the winch or the winch.
2 hours ago, Derek Priestley said:
hi Jeff,
You'll need it fixed for the big event in July!!
