Building Joysway B and C rigs
I’ve just acquired a B rig kit and was wondering if there was a set of instructions with dimensions for these rigs? I suppose it boils down to the position of the sheet fairleads and the position of the forestay and jib stay fitting on the mast?
Thanks
Simon
49 minutes ago, Stuart Z said:
Not seen one, would be interested if there are.
You know I have an idea that the mainsheet fairlead on the boom is the same as for the A rig, at least it needs to be pretty close to just astern of the ring on the bridle. As for the jib fairlead then that will be virtually over the sheet fairlead on the deck. The fiddly one is knowing the jib pivot point. Technically I suppose you want the aft end of the jib boom to be just a few mil forward of the mast but it would be useful if there was a distance in mm for that pivot point for all rigs in the Joysway assembly instructions.
Edited by SimonCornes
Thank you but it's a 65 - should have made that clear ! The dfracing website gives you instructions about the Soch sails, not Joysway but I'll have a look on You Tube - good idea!! Thanks
