one metre trim and rig set up
Hi
im new to this site and wondered if there’s an idiots guide to setting sail an rig
I sail a one metre home built model
billy
This link is to Brad Gibsons’s excellent guide to a basic setting up process for an IOM. I understand it works well for pretty much any design of IOM.
http://www.bgsailsanddesign.com/uploads/7/0/6/9/70698521/bg_sails_rig_tuning_iom.pdf
It’s very well put together. For me it’s the sort of document I need to revisit frequently because it covers such a lot of information.
One of the key points is getting the mast vertical as a starting point. This is tricky because when your boat’s on its stand, it’s difficult to see whether the design waterline is actually horizontal. I dealt with this by putting the stand on a smooth level floor and then moved the boat forwards and backwards to trim it until the bottom of the stern and forefoot were exactly the same height off the floor. I then checked the mast with a spirit level. Not perfect, but it provides a good baseline to work on.
Hi Billy
know the feeling…. And have spent most of the summer looking for hints and tips.
This is good
https://www.mya-uk.org.uk/wp-content/uploads/2015/10/20_IOMTuning_2013_2.pdf
as it appears to feature a boat similar to mine rather than the latest offering.
as Martin says, upright mast, and I was told the the front edge of the keel should be upright, and therefore in a stand with spirit level against this edge, you can adjust to get the boat as it should be in the water. Then mast upright from there.
but if I am wrong, happy to be corrected
Stephen
many thanks for your invaluable guidance and link which I shall endeavour to put to good use.  Thank you
Billy
