Right of way at a gate mark
Hi
Does a starboard running boat have any right of way over a port running boat that is also the inside boat at a gate mark of a course?
If no, then why does a starboard tack boat have right of way against a port tack boat at a windward mark?
Thank you for your help
Yes, stbd has ROW but gives mark room to an inside overlapped boat if they are rounding the same end of the gate.
There are some some exceptions in R 18 where mark room is not given. They are listed in R 18.1.
As it is a beat to windward, R 18.1.a says R 18 Mark room does not apply, and the port tack boat is not entitled to mark room. Just R 10 apples.
If you would like some homework, there is an article on the downwind gate in the Seattle IOM Newsletter June 2014 issue - starting at page 28.
Also there is an article on the windward mark in the October 2014 issue, starting on page 29
http://www.ibextrax.com/Update/
I have read the articles and they are very clear and informative. I have also started reading the other articles in the other editions. I recommend them as a good read.
graham
