Proteus EVO GBR 5244 FOR SALE
How does the Evo fit into the Proteus development series? I have an idea Craig Richards is testing the V5 at the moment. In addition, does your sale include the stand and a rig box? Thank you Simon
Ian Round joined the community
Paul Bowmer joined the community
Andy Banks joined the community
Thanks. I am in the South so too far for me
Gourock, Scotland - 15 miles west of Glasgow international airport Gordon
I am interested where are you located ?
Russell started following Proteus EVO GBR 5244 FOR SALE
This hull was built from the 3D printed kit of parts supplied by John Arundel and completed by myself to the highest standard last September. She has a measurement certificate and is at minimum. My intention at the time was that she would be my last of a long line of IOM's. Sadly since then my fitness has rapidly declined to the point where I can no longer sail competitively, so reluctantly she must go. The boat is completely fitted out with fittings from Sails etc , an S100 Mk 2 sail winch connected to a waterproof RMG deck switch, and has a Hitec waterproof rudder servo. The top suit is a little used moulded set to Crag Richards specification from Sailboats, while 2nd and 3rd are unused and from Pierre Gonnet. Price is negotiable around £800. For further information please phone me at 07772795657
Settings for Futaba rudder reversal and EPA
Hi Ian Glad to hear you got it sorted. As I stated in the originl post the Futaba T6J is not very intuative to use! It is however fairly robust and reliable to use. Just keep it dry and be careful where you position the aerial on rx if your Marblehead hull is carbon. Happy sailing with your controller. Eric
