Dual Rated M and 10R
We are considering a dual registration process in Canada and wonder how it works in the UK.
I have questions about how you handle dual rated M. When an M is also registered as a 10R does it get a different hull registration number from the 10R sequence? Is that 10R number displayed on the hull per 10R Class rules? If you do not have a PSN, which sail number do you show at a 10R event- the M or the 10R number?
Thanks for any insights
  • 3 weeks later...
Hi John,
As far as I know from having had several RM/R10rs, in the UK a dual rated Marblehead would need a RM registration number and a R10r registration number and both numbers would need to be displayed on the deck. The sails used would need to carry the last two digits of the relevant registration number unless a PSN is used. So PSN is definitely the way to go unless you want to keep changing sail numbers. If you could get the last two digits of each registration number the same that would also be a solution. Hope that helps
