Sail measuring
What are the rules now on sail measuring? I used to measure IOM's last century and in those days I signed and dated every sail I measured. Nowadays I see lots of sails without signatures or dates so is that now the accepted norm?
Many thanks
Simon
Hi Simon,
As we use the same certification process across all NCAs, as controlled by IOMICA, the answer to your question is, if a sail complies in all respects with the checks as specified on the IOM Certification Control Form for rigs and sails check list (refer link below) then the Official Measurer shall sign, or stamp, and date the sail.
https://iomclass.org/wp-content/uploads/2026/04/Certification_Control_Form_Rigs_and-Sails_Check_List_202678.pdf
So the real answer is no and they need to be signed and dated or be stamped and dated at a minimum.
Regards,
David
Edited by womble66
Typo
Thanks David, so a few unsigned sails about. I guess boats are built and sails measured and then sails replaced and not signed. Logically in that situation the sail maker aught to sign and date it because they have made it to spec and then the registration cert should be updated to reflect just that. Maybe one day it will be possible to update the cert online and just download it so no need to trouble a measurer?
I'll leave it to the MYA reps to comment but from my perspective as the National Registrar for another NCA, we don't accept sail makers certifying their own product but rather the onus is on the owner to ensure their IOM remains compliant and have any new sails certified independently by their NCA endorsed official measurers.
If new sails are not certified IAW the class requirements then they should not be accepted by an organising authority for use during an event ..... social sailing is another case.
Thats a fair point of view and very relevant to a some NCA's where the application of the class rule defines the sail area so it is incumbent on a measurer to ensure that the sail area is correct but with a class such as the IOM where the sail plan is defined in its external dimensions, if you are buying a suit of sails from an established sailmaker - and the sails are branded accordingly by them - then you would expect that the sails would satisfy the class rules as a matter of course and I imagine that any measurer of IOM's would confirm that that is the case? I have never found a suit to be lacking when measured in accordance with the rules anyway.
59 minutes ago, SimonCornes said:
....with a class such as the IOM where the sail plan is defined in its external dimensions, if you are buying a suit of sails from an established sailmaker - and the sails are branded accordingly by them - then you would expect that the sails would satisfy the class rules as a matter of course ...
It's a subject visited before, where people have sought to 'understand' the enforced separation between sailmaker and measurer.
Sail measurement https://www.mya-uk.org.uk/forums/topic/4446-sail-measurement/
3 hours ago, womble66 said:
... we don't accept sail makers certifying their own product but rather the onus is on the owner to ensure their IOM remains compliant
For sure the skipper must have the ultimate onus, but I reckon a sailmaker could be allowed to certify. Akin to a Company Director paying a fortune to a Chartered Accountant to prepare their year end accounts, but it's only the Director who is liable to HMRC for what is generated.
A sensible skipper would therefore buy from a reputable sailmaker who doesn't want to lose future business by being 'found wanting'.
Simon, a certificate does not need to be updated when new rigs are built. The certificate will have the same number of rigs as the original. The rigs do however need to measured, signed and dated.
