The Sedici is still a good design. Plenty of good skippers are still sailing them.
However if the designer has produced a newer design which has proved itself better why if you are travelling at considerable cost (money and time) would you not want to maximise you chances of winning or at least performing to the best of your ability.
It was not only Sedici against Venti but also Vickers V12 or V11/10, Viss or Kantun etc.
Also sail supplier is a major item, if I'm correct the winning skipper also made his own sails as he found his own cut suited his sailing.
I just wish I had the skills to maximise the performance of my own boats as I suspect any of the skippers sailing in the World's would be faster than me!!!!!!
