I've had a T6k for a couple of years now, when I first got it I was able to see RX voltage on the transmitter, suddenly, without changing anything I don't have it any more?
any ideas??
Have you changed the reciever lately? Do you have another reciever you could try?
You can check if RX voltage is selected by:
Parameter - Home Desp - Rx BatT
Edited by stevevw
Added Check setting
Ron Interesting topic as I have owned a similar Radio TX for a number of years and would appreciate that when you have discovered on how  to set to receive the voltage on the RX, please pass the information on, as I jave failed to do so on a number of occasions.
Raymond Crisp
Hi Ron
where would you say i should put the info im fairly good with radio kit. issues
Ron I have now discovered how to show the RX on the screen of a Futaba T6K. Menu No 2. PRMTR. Press Log Key Scroll Down to HOME-DSP. Select RX BAT. Press End Key twice to return to Home Page. RX Voltage shown
Thats what I posted on the 6th.
