Mast for IOM
Kieran, take a look at the IOM Gear guide from last years nationals https://gbriom.files.wordpress.com/2017/01/gear-guide-2016.pdf
The PG mast is the current fashion and can be sourced from CM Yachts or Dave Potter
It is worth asking the designer of your IOM for the recommended pre bend curve which is as important as the mast material.
The PG mast can be tricky to prebend and i'm sure if you ask CM yachts or Dave Potter they could also pre bend a PG mast for a small fee.
