Spreader forming/checking
Primarily for bending new spreaders to desired and equal angles.
Dimensioned for an IOM, with 11mm mast and 1.6mm linking rod.
The inner piece is intended for also helping to check angle equality after-the-fact, when shrouds are already installed in the tips and so can overhang the ends of it. [Unsure of the best width vs. 'discrimination of angles' for that - tried to aim for narrow enough to suit typical B rig on a typical narrow hull....]
