June 23, 20233 yr Hi looking for a mp3 file for 3 minute and 4 minute countdown for antimer unit I have built. Prefer it to be emailed, thanks Dave dave@kiwiyachting.co.uk
June 23, 20233 yr The following app is perfect for start sequences. It is configurable and in all languages. i can highly recommend it. https://apps.apple.com/app/id1357874791
June 24, 20233 yr Author I need it to be a MP3 file so I can upload onto ands card to put it into a machine that I have built
June 24, 20233 yr Hi David, not sure why you would want 3 or 4 minute timer for RC racing, as Appendix E specifies a two minute sequence, and the last minute has specific requirements (see below). You may download the AMYA 2 and 1 minute sequences here https://www.theamya.org/start-tapes.asp We use the 1 minute for most of our racing to speed up heats. There used to be an AMYA 5 minute timer for holds but that has disappeared. You could use sound editing software and edit and splice multiple copies of the first minute of the two minute sequence in front of the full two minutes to build your 3 and 4 minute versions. John E3.4 Starting and Finishing (a) Rule 26 is changed to:Heats shall be started using warning, preparatory and starting signals at one-minute intervals. During the minute before the starting signal, additional sound or oral signals shall be made at ten-second intervals, and during the final ten seconds at one second intervals. Each signal shall be timed from the beginning of its sound.
December 4, 20232 yr Hi David, I have a 4 min countdown on mp3. I put it on one of my timers but I must say I never use it. let me have your email address and I’ll send it to you, Geoff
December 4, 20232 yr 1 timer looks good for free app, two min or one min otions good to have on phone for small practices with mates before club racing starts… thank you, and with a blue tooth speaker would be good
December 5, 20232 yr On 04/12/2023 at 22:37, Stephen B said: 1 timer looks good for free app, two min or one min otions good to have on phone for small practices with mates before club racing starts… thank you, and with a blue tooth speaker would be good The app is great. One problem we had either the Bluetooth speaker was that the speaker switched off between the countdown voices and always cut off the beginning of the next voice. probably this is speaker specific. I have not tried it with a different speaker yet. the app is really great though
December 6, 20232 yr I use a waterproof speaker (intended for use in a shower!) and this stays connected for several minutes after the voice signal stops. There are a plethora of free timer apps out there. This one has a rather nice horn at the end of the countdown. https://play.google.com/store/apps/details?id=ypsilon.app.cdn
