RoRo Posted October 7, 2022 Posted October 7, 2022 The way l have been told and used is to get a hard surface (l use a cutting mat) the carefully put the sail on the mat with the crease pointing upwards. The use a credit card or something similar to run up the line of the Crease. I repeated this then turn sail over repeat then turn sail over repeat. After this it flattened the crease but l can still see where it was originally indented but it's now flat. Hope that helps. If anyone has a better way please chip in as l would also be interested. Rohan
Trevor Posted October 7, 2022 Author Posted October 7, 2022 Thanks RoRo. I'll give that a go. I tried warming with an air gun and rubbing with my fingers which has helped a bit by making the crease less pronounced.
Register a new accountSign in
