Two Futaba T6J handsets with bound receivers R2006GS and supporting instruction manuals. Happy to sell as a pair or separately (discount for 2) Note: One has a missing spring in battery section (probably easy fix)….. so will provide a power pack for that one. Mark.rose47@btinternet.com Aiming 70 each Ono
Unidentified model
Unidentified model
Unidentified model
DF65 Bare Hull & A Sails
Colin Helliwell started following IOM Worlds daily report?
I watched all of the seeding races and then only the A fleet races for races 2 and 3 as life is too short! The impression I got was that they would upload races on later days as soon as they could but it must have been a good 3 1/2 hours if you'd watched all of yesterday ! I also noted that they said that the couldn't afford the live streaming that the Australians had managed due to the exorbitant cost in the UK which is a sad reflection on how we pay through the nose for everything! I don't blame the MYA for being sensible.
